front end noise
front end noise
I have a 1994 sport 2wd. Every time I go over a bump in the road or a few bumps at a time it will make a clunking noise in the front. But sometimes when I go over the same bumps I apply the break just a little tiny bit and the noise will not happen or be not as bad... I checked the shocks and the knuckle and arms and found everything to be tight. Not sure if it's a rotor bearing problem making the caliper make that noise every time the truck hits a bump... but it's getting worse and happing even on little bumps in the road.
