Front End Shakes When Braking to Stop
When braking to stop my 94 Ford Explorer, what could cause the front end to shake so bad to the point where it feels as if it's in a sense going to fall off? Also, other than the oil being low, what could cause the lifter noise? Whatever your possible diagnosis is for my Ford Explorer problems, can you give me a possible estimate as to how much these repairs are going to be? I understand it will vary as to the location of where I take my vehicle, etc, but I'd just like to have a rough park estimate if possible, so I know what to expect. Thanks so much for your time.
RE: Front End Shakes When Braking to Stop
You more than likely have severly warped brake rotors? Could also be severly rusted rotors that cannot be turned, could also be worn out radius arm bushings. If your vehicle is a 4x4 explorer the rotor replacement will cost you in the neigborhood of $375 plus an incedentals brake pads, calipers, etc..... Radius arm bushings cost approx $200 parts and labor if frame pockets are not worn out. If you have 2 wheel drive explorer the rotor replacement will be considerably cheaper because 4x4 hub disassembly is not necessary.
