Fuse #41 Problem!
Fuse #41 Problem!
The other day fuse #41 blew and my car stalled. I did some research and almost everywhere i find people say to check the O2 sensor wires because they say they get burnt and short somewhere. So i checked all 4 sensors and they are all good. I do not know where to look next! Any tips?
Why don't you replace the fuse and see what happens. If it blows again right away you know there is a direct short. If not, then you are going to have to move some wires around and see if you can create the condition that caused the fuse to blow.
Do you have your owner's manual?
In there it should tell you what that fuse protects.
That will narrow your search down to a more definite area. Come on, let's get hoppin !
