headlight replacement 95 explorer
RE: headlight replacement 95 explorer
I replaced the headlamp bulbs on my 95 last month. Pop the hood, there is an access panel on the top left and right. Open it up and stick your hand down and twist and pull. It is a bit tight, especially on the driver side becase of battery, but is doable. Pop in the new ones and reverse the procedure.
