HELP! Thermo Stuck at Cold/Check Engine Light
Old 02-18-2006 | 06:30 PM
South Side Polish's Avatar
Default HELP! Thermo Stuck at Cold/Check Engine Light
My Thermostat is stuck at cold, never moves no matter how long the engine is running. Also, the Check Engine light has been on. Could these two things be related? Any help would be greatly appreciated.
Old 02-18-2006 | 06:34 PM
Default RE: HELP! Thermo Stuck at Cold/Check Engine Light
Forgot to mention, 2000 Explorer Sport 6.0L
Old 02-18-2006 | 06:39 PM
I mean 4.0L, as you can see I have no idea what I'm talking about.
Old 02-23-2006 | 05:56 PM
I_AM_AN_ENGINEER's Avatar
The code will be for engine not at expect temperature. Replace the T-Stat with new and the code should go away. If it does not go away unhook the battery for a minute or so to clear the codes... If the codes are real they will come back.
chuback
03-11-2013 05:47 PM
chuback
03-07-2013 09:36 PM
m3steve
12-05-2011 03:19 PM
South Side Polish
02-22-2006 03:28 PM
skid2964
01-08-2005 11:01 AM
