Keyless entry 2016
Keyless entry 2016
I have a 2016 Explorer Sport, and when I try to use the keyless entry I get a red dot at the top of the panel and nothing works. Any suggestions why this is happening? It worked before but now all of the sudden its no-op with that red light at top.
Ok so if the red dot comes on you've got power and ground. I would agree just replace the trim panel, every keyless entry pad fault I've seen has been the key pad itself.
The part ranges from $200-$300 usually and I believe labor time is around 1.5 hours so honestly the quote sounds right.
If you are willing to fight/cut your hand up a little with routing the wiring through the door for about an hour or two I can post instructions for how to replace it so you only have to pay for the part.
