low idle @cold start
Old 01-17-2006 | 03:11 PM
john2windows's Avatar
Default low idle @cold start
4.0 SOHC Idle runs 400 to 700 and wants to stall during first 1 - 2 minutes. Gas mileage is poor now maybe 12mpg. Have replaced IAC 8 months ago. Engine runs fine after 2 minutes with no loss of power. Sprayed carb cleaner around base of intake with no change. Someone suggested replacing coolant temperature sensor. I can see it but unable to get there.
Thanks
Old 01-17-2006 | 07:10 PM
jjngh1's Avatar
Default RE: low idle @cold start
I have the exact same symptoms with the same engine except with check engine light.
Im taking it in for a diagnostic check.
Ive heard o2 sensor or maf sensor but wont know for sure until I take it in.
FYI I changed the fuel filter with no results.
Old 01-21-2006 | 12:47 PM
Honest John's Avatar
Hi John, What year is your Explorer?
I had purchased a used 1998 that was doing what yours is, and when I went to the dealer, I learned there was a recall for the head gasket.
There was a heater switch, or something like that, I think, that was taken care of also.
But that switch was not the cold start up problem, the head gasket was.
And I did get a new spare tire because it was a firestone.
I had them replace every hose, belt, and clamp while they were in there replacing the head gasket.
I see there are a few posts around here, that sound like the same problem?
Peace Out
Michael Leonard Woodcock
12-10-2012 09:36 PM
tsjonesmusic1
09-12-2011 08:29 PM
jimmijones
01-04-2010 07:01 AM
HOTTUB3
03-06-2008 08:21 PM
