radio doesn't turn off when pushing in button
Old 03-15-2009 | 11:30 PM
anoll62's Avatar
Question radio doesn't turn off when pushing in button
On my 1997 ford explorer the radio will not turn off when pushing in the volume / power button. RAdio turns off when car is turned off, but can't be turned off via switch. How can you remove front panel on radio to get at this switch?
Old 03-18-2009 | 03:04 PM
oldtimer35's Avatar
You can remove the radio with a puller tool. I believe your has the two holes in the faceplace on both sides. Then the front cover comes off fairly easy with about 4 screws and then lifting tabs around the face. You can access the switch at this point, but not sure where you will get a replacement.
Janice Procyshen
02-21-2015 06:23 PM
acrilyc
07-31-2012 04:09 PM
Steveromo
05-05-2011 08:14 PM
showme6.0
03-12-2011 02:40 AM
