Radio reception
Old 12-28-2007 | 05:52 PM
pcm's Avatar
pcm
Default Radio reception
My 99 XLT got introduced to a deer a little while ago at 50 mph. Glancing blow off the right front. Not too much damage. Fender, headlight, some trim.
The issue now is that my radio reception stinks. No AM at all. Picks up nothing. On FM, only the strongest stations come through clearly.
I mentioned it to the body shop and they said they saw nothing on that end to indication a problem with the antenna.
Would be possible, in the crunching, that the antenna got yanked and is not plugged securely into the radio?
Can i get to that without taking that center cluster panel apart? Can I remove the inside of the glove compartment and reach up in to check? It's Maine in the middle of winter and I have no inside work space.
Short of that, how do I get at the radio so I can check that connection? Am I looking at the wrong end?
Other thoughts?
Thanks in advance.
Radioguy
11-28-2010 08:46 PM
withers,b
05-09-2010 10:49 AM
Mistrfixit
02-03-2009 12:02 PM
kimsxr8
04-27-2006 01:55 AM
kimsxr8
01-17-2006 03:29 AM
