Rear Taillight
Old 02-12-2007 | 01:41 PM
01ExplorerSport's Avatar
Default Rear Taillight
I am having trouble with my rear passenger taillight/blinker on my 2001 Explorer Sport. I have replaced both the bulbs as well as the fuse and still luck. Anyone have any ideas?
Old 02-14-2007 | 06:56 PM
mayday's Avatar
Default RE: Rear Taillight
Does it light up at all? Reverse lightingI take it is completely out. Could bea ground problem for that corner section of wiring.
Old 02-16-2007 | 05:25 PM
I think it lights up when I am in reverse. But that could be incorrect also. I could have imagined seeing red brake lights in the reflection. How easy of a fix is this? Is it a possible do-it-yourselfer for an amateur, or do I need to suck it up and get a mechanic to look at it?
Old 02-19-2007 | 11:28 PM
mayday's Avatar
A voltage meter will tell you for sure where the problem is. By tracing the wiring -starting at the bulb's quick disconnect- and working your way back into the cargo area. If this is something you don't feel comfortable about, take it to someone whocan fix it right.
Tabanos
05-14-2008 12:08 PM
lindenberg22
03-24-2008 11:16 AM
uglysam
12-15-2006 04:33 PM
danny88
09-02-2006 01:59 PM
Quick Reply: Rear Taillight
