rev limiter
Old 07-14-2007 | 08:26 PM
iplaypearldrums's Avatar
Default rev limiter
My explorer wont rev over 3000RPM in park.........is there a rev limiter? 2002 sport explorer
Old 07-15-2007 | 12:05 AM
Default RE: rev limiter
Engine RPM/Vehicle Speed Limiter[/align][/align]The powertrain control module (PCM) will disable some or all of the fuel injectors whenever an engine rpm or vehicle overspeed condition is detected. The purpose of the engine rpm or vehicle speed limiter is to prevent damage to the powertrain. The vehicle will exhibit a rough running engine condition, and the PCM will store a Continuous Memory DTC P1270. Once the driver reduces the excessive speed, the engine will return to the normal operating mode. No repair is required. However, the technician should clear the PCM and inform the customer of the reason for the DTC.
Excessive wheel slippage may be caused by sand, gravel, rain, mud, snow, ice, etc. or excessive and sudden increase in rpm while in NEUTRAL or while driving.
Old 07-16-2007 | 02:51 AM
Thanks......the Exp, has been sitting since Jan. other than its bi-weekly startup/trickle charge wax n wash while it waits to get tagged. I thought it was forked since I didn't run it on the interstate and blow out the carbon.
Old 08-27-2007 | 04:53 AM
dundonrl's Avatar
mine does the same thing.. won't go over 3000 rpm in park or neutral.. guess it's something built in to save the engine from over reving.. (I found out about it 6 months or so after I bought it)
Focus7081
05-18-2011 12:23 PM
Focus7081
05-11-2011 10:00 AM
rick cole
08-04-2009 09:49 PM
MMatthews90
07-17-2006 11:10 PM
taffy151
07-12-2006 02:43 AM
