Should I switch to synthetic or half-synthetic oil?
Old 05-19-2009 | 08:29 PM
fl_hayseed's Avatar
Default Should I switch to synthetic or half-synthetic oil?
I have two explorers, mine is a 2000 with 140k and my wifes is a 1997 with 120k. I would like to switch them both to either synthetic or half-synthetic as I have been taking them to the dealer and getting the cheap stuff. I used to use Castrol Syntec (half synthetic) in my 92 Ranger which had 212k on it when I sold it 2 years ago and I still see it driving around. I would however appreciate any suggestions or recommendations anyone could give me. I would especially like to be directed to any sites that compare the oils by a non-biased party, (non manufacturer). Is it better to go half synthetic for a number of years and then go full, or does it matter? Let me know what has worked for you.
Thanks,
Randy
Old 05-26-2009 | 10:28 AM
Use Common Sense's Avatar
I would go FULL SYNTHETIC for the price difference between a FULL and a SEMI-Synthetic lubricant.
My personal preference is ASMSOIL. Have been using it in everything I own/have owned with "0" problems.
I presently have AMSOIL in my following items since new:
1979 Gilson Snow Blower - Model 5148 (Engine, Geer Box, Tranny) (Bought from original owner who never used it)
1995 Honda Self-Propelled lawn Mower (Engine)
1999 Campbell Hausfeld 2500 PSI pressure washer (Engine)
2004 Ford Freestar Limited (Engine, Tranny, Power Steering, Oil & Air filter)
2003 Poulan 2-Cycle Weed Trimmer (100:1 Pre-Mix)
2005 Yardman 2-Cycle Roto Tiller (100:1 Pre-Mix)
2007 Farm-Hand 3-Cylinder 5 HP Air compressor (Compressor)
2007 Generac 17.5KW Generator (Engine, Oil filter)
2008 Airens Snow Blower - Model 11528DLE (Engine, Gear Box)
2008 Sable (Engine, Tranny, Power Steering, Engine, Oil & Air filter)
2008 ECHO PAS-265 2-Cycle PRO Attatchment unit (100:1 Pre-Mix)
2009 3,000 PSI Troy-Bilt Pressure Washer (Engine)
Old 05-26-2009 | 02:50 PM
oldtimer35's Avatar
At the mileage you have on your vehicles, I don't see any reason to change from Ford's Synthetic Blend to a Full Synthetic. I doublt that it will improve the life of the motor, if you have been getting it serviced on a regular basis. Your Full Synthetic will run about 7 dollars a quart or better and the 5W20 or 5W30 (depending on motor) that goes into a "oil change special" runs about 2 dollars a quart. The reason for the price difference is that Ford sells the 5W20 and 30 in the hundreds of gallons at a time verses by the quart. I have used the Motorcraft Synthetic Blend in my vehicles for years with no problem. My 90 model that I gave to my grand-daughter is approaching 300,000 miles and runs like a new one, with no oil comsumption. My 98 that I drive to work has 240,000 on it and again no problems. I do run the Full Synthetic in my 04 Lariet, just to get another mile or two per gallon out of it. Just my 2 cents worth.
Old 05-15-2013 | 05:31 AM
Angelo Bellezza's Avatar
Any FRESH, CLEAN oil is fine. Just make sure you change it at the recommended interval.
Old 11-18-2016 | 02:26 PM
jwilson4786's Avatar
I have been using Castrol High Mileage 10W30 for over 100,000 miles on my '96, changing every 5000 with new filter. It is a semi synthetic, the only noticeable problem is I lose a 1/2 quart over that time from leakage. Have 300,000 on truck, runs great.
Old 11-18-2016 | 07:42 PM
Late model Ford engines are particular about the grade and type oil used. Not using the recommended grade can be a recipe for problems.There are reasons for their recommendation and sometimes a better quality oil is beneficial as long as the proper grade is used.
Old 04-03-2018 | 12:03 PM
Jerbear's Avatar
Default engine oil
Especially on newer vehicles it is very important to stick with the viscosity of oil the mfg. recommends for proper lubrication . I just read that in the USA the oil company's are required to put 5% full synthetic oil in the synthetic blend oil. My personal opinion is either buy full synthetic for a couple dollars more or stay with regular oil .I think the synthetic blend is a sales gimmick because while the blend may be a tad better than regular oil your paying much more than regular oil and your not gaining that much for your buck. We have a tenancy to think the blended is about 50/50 .I would say that the companies don't go much above the required 5% of full synthetic.
SVTgurl
03-23-2024 12:14 PM
greuelc
07-12-2022 08:41 AM
Mark B
11-07-2014 06:57 PM
Fusion13
11-22-2013 03:49 PM
Davem4notw
08-23-2011 10:09 AM
