Speedometer Reading
Old 11-13-2005 | 03:04 AM
edeanda's Avatar
Default Speedometer Reading
Hello Everyone,
I have a 1998 Ford Explorer, Eddie Baeur 4x4 and I have noticed that every time that I drive towards the active speed signal in my hometown, the reading on the signal is about 4 mph less than what the speedometer reads in my explorer. I have a feeling that my speedometer indicates that I am traveling at a faster speed than I actually am. Have any of you notice this problem with your explorer? I checked out the tires, and they're stock: 255/70 R16. Is there any way to make sure that the speedometer is giving me the correct reading? Thanks in advance.
Best,
Eric
Old 11-13-2005 | 02:01 PM
SNKPWR's Avatar
Default RE: Speedometer Reading
the most accurate way to check your actual speed is to drive for several miles on a road that has the miles marked, and time yourself over a distance...and convert to MPH...
that being said, if your tires are worn close to the wear bars, you will see a slightly higher speedometer value than when the tires are new...
stevenjames
02-10-2009 07:58 PM
stevenjames
08-17-2007 01:37 PM
427435hp
06-03-2007 07:43 AM
frankd
11-25-2006 10:02 PM
jp_waltz
04-24-2006 04:59 PM
Quick Reply: Speedometer Reading
