tensioner pully
RE: tensioner pully
No if you are trying to change the belt.There should be a square hole by the tensioner .Put a 1/2 inch drive ratchet in there and pull it one way or the other to release tension on the belt.Thighten the bolt if this thing get's loose you may get hurt
