turn signal problems
Old 03-27-2007 | 03:36 PM
braydee0521's Avatar
Default turn signal problems
My high beam (turn signal) will lock forward but the high beams do not come on. The only way the high beams work is if Ipull the turn signal back and hold it back. If I let it gothe high beams turn off.
Old 03-27-2007 | 04:19 PM
goinstrong's Avatar
Default RE: turn signal problems
The switch sounds like it is broken - replace it. Pulling back is the flash for the high beams and is normal (used to flash high beams if someone's blinding you).
Glowbug
01-28-2022 01:43 PM
makuloco2000
08-25-2014 10:08 AM
grandmarquisNM
07-21-2012 11:30 AM
jjam20
03-29-2008 03:32 PM
pixleyyy
03-28-2007 12:08 AM
