Windows - Diagram or advanced help needed
Old 01-29-2008 | 01:32 AM
JC's Avatar
JC
Default Windows - Diagram or advanced help needed
'98 Explorer
All windows won't work, won't go up or down, but everything else in the truck (that I can think of) works still.
I searched around the forum and couldn't find what I needed in the other window posts. It doesn't seem to be the relay many people mentioned here or on usenet
No noise, no lights flickering, tried using all door switches and window lock switch is in correct position.
The condensed version of the following is that I could really use a wiring diagram for the whole window circuit and to know exactly what the GEM is, where it is, and what part it plays in the circuit, as well as how to check the master window button panel, and to know if I've overlooked anything else.
I checked all fuses and I *think* all relays (side of dash, under hood, and in module under dash). There were only two models of relays so I tried swappingthem around (both the smaller ones and the larger 1" cubic part # F0AZ14N089A under the dash, but no luck. I wouldn't say the fuse and relay contacts were completely clean but looked in good shape, truck is garage kept and inprettygood condition. Does anyone have a diagram of the under dash relays and the wiring diagram for that relay box?
I have a fair amount of electrical / electronics skill including some test equipment but don't know where to check next. I could end up tearing apart the whole door and ripping off all the wiring wrap from the main box under the hood all the way to the motorin vain because it's not so easy for me to trace wrapped and bundled wires. I was hoping someone has a wiring diagram or schematic, or at least adescription of the whole circuit from the battery to the window motors (pleasea very clear description withoutabbreviations, for example I have no idea if a GEM is just a plastic box with relays in itor a controller circuit board orsomething else?) I looked in the owners manual and on Autozone's website but didn't see anything.
I probed around a bit and took the driver's side door panel off hoping to see a connector but only saw a wiring harness. I guess the connector to the master window button panel is down inside the door? If/when I get that off (if necessary), does anyone know the pinout for the master window switch harness connector?
I apologize to the person who posted the following numbered list because if I remembered who it was I would give them credit but here is a list of things someone said it might be a while ago, and my comments or questions about these:
If all windows are inoperative, then in order of likelyhood:
1. Power window master switch on drivers door.
How does this fail? I mean does it's failure prevent the other passenger door switches from working?Can you visually or audibly tell it has failed? It looks clear and button feedback pressureis normal. Does anyone know the pinout or wiring color designationsfor this so I can more easily probe it with a multimeter without having to completely disassemble it(if that's even possible?)? Is there any danger in just taking a length of wire with a 10A fuse in the middle and connecting a few of the contacts on the back together to see if it opens any windows? Does the switch panel in the door directly power the windows or does it energize a relay for each one? If it energizes a relay are those the other smaller relays in the box under the dash?
2. Accessory delay relay
Is this the 1" cubed, only larger relay module in the box under the dash? I swapped this with another one from the under-hood box withno luck. I do hear one (I think only one) relay energize under the dash when I turn the key just before starting the truck. As far as I can tell, I hear no new relay sounds when I press a window-switch button on the door but I don't know if I should hear anything then.
3. GEM Control module.
What exactly is this, where, what does it look like, and what can go wrong with it? I hope for all the information you can provide because there is a good chance I can even repair this if it is a circuit board component failure, if only I had some info about the general wiring scheme and logic used to get windows working (LOL!).
4. Circuit problem - bad, broken wire, etc.
The wires look fairly hard to trace, is it true that with a given color + stripe color, this color combination will only be used from one point to the next, never reused from the 2nd point to somewhere else or from the 1st point to somewhere besides the 2nd point?
What would be easier for me to do is check continuity from connectors to fuse and relay sockets, etc,with a jumper wire and multimeter if I had the wiring diagram. I had even begun to check for 12V at the fuses but then realized I need a diagram to know where to look next.
Thanks for your help,
JC
Old 09-09-2008 | 09:41 PM
cmoy's Avatar
Default RE: Windows - Diagram or advanced help needed
Jc,
Did you fix your window problem?
I have the same problem on my 2005 Ford freestyle.
I posted on the freestyle forum a couple days ago.
cmoy
Old 09-09-2008 | 11:52 PM
JC's Avatar
JC
Yesit's fixed. Somehow when I'd been looking over the wiring harness bundle that passes through the rubber boot from the door to the front quarter, Ididn't see one of the wires had a funny kink in it. I took a second look at that area by just pushing the boot out of the way and saw the bad wire. It just needed to have that area of the wire cut out and soldered together again.
I'd meant to post that result in this thread, can't remember now why I didn't... must've forgotten or figured nobody was reading it since there weren't any replies. Sorry about that.
Say, are you Chu Moy from headwize? I used to spend some time there, though more time on head-fi (user:Mono). The irony is I remember a time on headwize when there was something wrong with the editing system and when I edited a reply it resulted in strange characters appearing in posts. The same thing just happened with this post, above I typed only one apostrophe per word but it keeps putting more of them in the post. I'd edit them out but I already tried doing that once and it still made more.
Old 09-09-2008 | 11:59 PM
Thanks for the update..
sweeetbabyjaims
06-02-2011 11:45 AM
DIY_Dude
07-24-2010 12:57 PM
Alex
12-04-2007 07:40 PM
Cougar_Vibe
01-17-2006 07:25 PM
scpunx69
12-17-2005 02:52 AM
