wiring diagram ford mercury/explorer 97
can anyone tell me where i can locate on-line a wiring diagram for the mountianeer/explorer? some one must have one i can download? i have a rear wiper problem that may be a switch or computer related. i bench tested the motor and it works. it will work one time in the car but causes a bunch of non related problems elsewhere. i found a wire shorting out in the engine bay where the large plug is located. this wire may have started the problem. i had the pcm fuse blow out a few times and then found this wire hitting a bracket and shorting. can't say if this is the cause of the rear wiper but without a wiring diagram to check it out won't know for sure.
if anyone has any ideas feel free to send them along. thanks bob p.
RE: wiring diagram ford mercury/explorer 97
try this one hope it helps .Dont know what all it covers .
http://www.autozone.com/servlet/UiBr...3d800ba9c7.jsp
marksatterfield
04-09-2013 01:48 PM
