1985 F150 brakes
Old 01-31-2008 | 11:21 AM
rootercycles's Avatar
Default 1985 F150 brakes
Hey All,
I have a 1985 F150 that I have completely replaced the brake system front to back.I have a baffling problem. Over a month or so, the front reservoir on the master cylinder goes dry and I lose about 50% of my brakes. Each time this happens, I trace all lines to each wheel only to find there has been no leak anywhere. I have replaced the master cylinder twice, including bleeding before installation, and bled each wheel. The problem persists. I know this supplies the rear wheels, but there is no sign of leaks anywhere and therear slavecylinders work fine once bled. Any clue as to what is happening?
Old 01-31-2008 | 02:06 PM
oldtimer35's Avatar
Default RE: 1985 F150 brakes
Pulled both rear wheels and check the wheel cylinder cups for leaking? Run the brake lines and no sign of dampness? Checked the splitter at the rear diff and it's ok? Someone drinking your fluid?[sm=alien.gif]
Old 01-31-2008 | 04:05 PM
if the rear slave cylinders were leaking, wouldn't they drip down onto the wheels? The junction is fine (without leaks)above the rear differential. No leakage from the brake lines that I can find.
Old 02-01-2008 | 01:18 PM
oldtimer35's Avatar
They should, but if you don't see fluid anywhere else, then I'd put and eyeball on it. [sm=mail.gif]
nemakx125
03-11-2008 01:37 AM
wilhite43
02-21-2008 04:59 PM
wilhite43
01-13-2008 11:34 PM
rootercycles
01-01-2008 07:51 PM
kmillion91
02-23-2006 10:01 PM
