1986 ford f150
Old 03-24-2009 | 11:00 PM
vmx555's Avatar
Default 1986 ford f150
it idles good but when you give it gas it dies (new plugs,fuel filter,plug wires) need help
Old 03-25-2009 | 07:16 PM
way2old's Avatar
Check the Throttle Position Sensor. Sounds like that may be the problem.
Old 03-26-2009 | 06:37 PM
vmx555's Avatar
well replaced that still doing the same
Old 03-27-2009 | 09:44 AM
Bullitt94's Avatar
Does your cap and rotor look good?
Would your timing be off for any reason?
Vacuum leak somewhere?
Old 03-29-2009 | 10:36 AM
vmx555's Avatar
i found out my erg valve was plunged order a new one hope this fixes it replaced map sensor if not thinking its my fuel pump its making a noise
Old 04-16-2009 | 04:48 PM
vmx555's Avatar
got a code reader here are the codes i got need help
pip circuit failure
evap control system below minimum voltage
tps circuit fault,below minimum voltage
primary fuel pump circuit failure
thks in advance
thekid_jesse
05-27-2021 05:19 AM
shadow11
05-05-2008 02:24 PM
spf150
03-22-2008 11:24 PM
Ford Master
02-03-2008 09:21 AM
ck_russell
10-11-2006 01:13 AM
