1990 Ford F150 with a bad miss
Old 08-20-2007 | 08:41 PM
sherry1988's Avatar
Default 1990 Ford F150 with a bad miss
[:@]I have a 1990 Ford F150 XLT Lariat. It has a bad miss. I have had it to the shop and they have put a new injector, and coil in it. I have also replace the plugs, wires, rotor, cap. It seems like it is not running on all 8. If you take it up a sligt incline you have to shift it into 2nd gear to try to make it up. The Exhaust smells really rich. My truck only has 84,000 mile on it. Can someone please point me in a good direction??
Old 08-21-2007 | 09:25 AM
Bullitt94's Avatar
Default RE: 1990 Ford F150 with a bad miss
What do you mean by miss? Does it shake when you try to accelerate? Does it idle well? Does it run at highway speed well?
Old 08-21-2007 | 07:50 PM
sherry1988's Avatar
Thanks for the reply,
The truck does not idle properly, it shakes and acts like it is only running on 6 cylinders. When you take off in first, runs bad, second runs worse, third just as bad. I take the interstate to work. 4th gear is what I have to run in. If I put it in 5th, forget it. It just keeps losing speed. If I am on flat ground with no minor grades it runs rough, but will at least go. When you give it gas it just falls flat. I quit running it today. It is to bad. I am afraid itmight leave me sit.
I tried to go through town (lots of stops and starts at lights) it is worse when you have to start and stop. If Ican tell you anymore pleaselet me know.
Thanks
Old 08-22-2007 | 08:37 PM
02greenF150's Avatar
Almost sounds like a timing issure. or possible a Mass Air flow Sensor.
Old 08-22-2007 | 10:01 PM
greuelc's Avatar
Try a compression test and even testthe fuel pressure.
Old 08-23-2007 | 06:13 PM
Bullitt94's Avatar
Also, while it is running, spray some starter fluid, carb. cleaner, etc. around the seals of the intake. If you hear the engine rev, then you have an intake gasket that needs replacing.
Old 08-24-2007 | 08:04 AM
Use Common Sense's Avatar
You could also have a fuel pressure regulator that has a failed diaphram. This will allow excess fuel to enter the intake thru the vacuum port. Pull the vacuum line off of the fuel regulator and check for fuel in the vacuum line. If no fuel is present, then the fuel regulator is probably OK.
opie01
01-29-2014 03:15 PM
skip1930
01-26-2013 06:19 PM
rlpatte
03-31-2012 09:45 PM
finne22
11-04-2009 08:51 PM
paf150driver
08-12-2009 06:42 AM
