1991 f150 brake issues
Old 12-30-2011, 01:59 PM
amercanfisher93's Avatar
Does anyone know how many motor mounts are on a 1985 5.0 f150 motor, only 2? i would make a new post but i can seem to figure out how...ive been looking for a while now, sorry for the intrusion.
  #12
Old 12-30-2011, 02:31 PM
Jamesvlt's Avatar
The brakes were no good when I bought it. Ive been trying to fix them for the past 3 weeks. Began by replacing front lines had issue after issue so it led to buying all these parts. Couldn't get the old bleeders loose so bought calipers and wheel cylinders. All break lines were rusted to hell.. Couldnt build pressure so replaced booster and master. Yes two ppl have been working on it to bleed it. We check calipers but not very thoroughly, but that's a valid point we will check them more closely..
  #13
Old 12-30-2011, 02:54 PM
There should be one on either side of the engine and one on the rear of the trans if my memory serves me correctly.
  #14
Old 12-30-2011, 07:17 PM
bobv's Avatar
If you blocked off the mc and the pedal is hard the mc is not the problem!
Try this Block off the rear brakes before the eh valve the pedal will be hard.
Next block off the brakes after the eh valve if the pedal goes down replace the valve.
One of the symptoms of a eh valve gone bad the pedal will seem good before the engine starts. After the engine starts the pedal will creep down almost like a bad mc. I will bet the eh valve is bad.
Bob
  #15
Old 12-30-2011, 09:33 PM
Jamesvlt's Avatar
Well it's only blockin the front that it stiffens up once u hook up the front u loose the pedal
  #16
Old 12-31-2011, 05:19 AM
bobv's Avatar
do you have good flow of fluid in the front lines .If so block one side off at a time see if there is a problem with one caliper its looking like a problem in the front lines or front calipers. check close for leaks.
Bob
oklmish9
10-15-2013 02:14 PM
roadcoupe
03-20-2013 03:24 PM
Richard O'Rourke
02-10-2011 03:00 PM
musicfire1
08-30-2006 09:04 PM
zoswinner
01-08-2006 03:35 AM
Quick Reply: 1991 f150 brake issues
