1991 F150 refrigerant
It is either R-12 or R134A. Look at the connections on the lines. If the threads are on the outside, (looks like a small tire valve) use the R-12. If there are no threads and it is a quick disconnect style, use the R134A
1991 F150 refrigeant
Thanks way2cool, i appreciate the help. Another issue is there is what looks like a pressure switch attached to the top rear of the ac compressor. There are two wires coming out of he top of this switch. Where do they connect to? They have been cut and I cannot find the other ends anywhere.
Thank you
Thank you
