1993 4.9 oil pan bolt sequence
there isn't a sequence for the oil pan but you 'll have four bolts that are bigger than the rest and they go in the corners beside the main bearings as far as the intake goes you start in the middle and work your way to the out side ends in a X or cross bolt pattern in three stages. if you need a diagram for the sequence then you go to Autozone or the local parts store and have them to print out a diagram for you usually for free. and it will give you the sequence and the final torque of the bolts. good luck and welcome to the sight
