1993 ford f150 ticking
i have a 1993 ford f150 xlt with a 351 5.8 v8 engine in it. i recently changed spark plugs to autolite platinum ones. they were the same that were already in the truck. however now i have a loud ticking noise when start the truck. it only started after i changed spark plugs out. any more information i will be glad to give it to whoever has dealt with this before. thanks in advance for any help i may recieve
ya. i have taken spark plugs completely out. found one banged up one replaced it again and that stopped the roughness. while putting them in i did spray threads and plugs with electric cleaner and put that silicon grease on. Anyways i think the engine ticking is actually my power steering. the thing sounds like a motorcycle when i first start it and then when its running only if i turn all the way right. any ideas on if i should fix it or replace it. n what power steering fluid should i use.
FordGalaxie885
06-16-2013 09:20 PM
KINGDELL
04-13-2008 11:01 AM
