1994 F150 will not run
Old 04-08-2013 | 12:04 AM
Nick Gibson's Avatar
Default 1994 F150 will not run
Crashed drove home next day fuel pumps not working right. When it was running the front pump stopped working and the back pump did then the back pump pushed all the gas to the front tank after getting it to run for about 10 min i lost all pumps and spark did i cook the computer?
Old 04-08-2013 | 02:10 PM
Before you get involved with replacing a computer that might not be defective, You must replace the front tank pump module. That will correct the returning fuel to the wrong tank problem. If you ran the pump for the rear tank dry thinking it had plenty of fuel , you could possibly have burned up that pump. I would suggest you check all the fuses first, then the fuel pump relay, and then the inertia switch.
Not sure about the "crashed" part. Did you have a mishap or were you that tired?
If a mishap , the inertia switch is a good thing to check.
boaterdude83
04-02-2009 01:29 PM
mano
06-28-2008 09:43 AM
Rclark91f150
03-26-2007 01:48 PM
dallas
10-27-2006 10:53 AM
Lennygrt
04-30-2006 08:55 PM
Quick Reply: 1994 F150 will not run
