1996 ford f-150 302 engine automatic
Old 07-30-2012 | 12:45 PM
bandit1948's Avatar
Default 1996 ford f-150 302 engine automatic
i have a 96 ford f-150 302 automatic ! the overdrive button is on the gear shift and when i push the button the overdrive lights up on the gear shift ! am i in overdrive when it lights up or is it out of overdrive ? it has the automatic overdrive transmission ! i was told to leave the button alone unless i am pulling a heavy load and need the extra power ! i was told when the light lights up on the gear shift it means it,s out of overdrive ! if you can understand what i am saying then i appreciate some help on this matter ! i don,t have the owners manual that comes from the factory and this truck is all new to me ! thanks guys !
Old 07-31-2012 | 12:43 AM
granpabobby's Avatar
When the light is on you are OUT of overdrive..
Old 07-31-2012 | 10:42 AM
bandit1948's Avatar
thanks man ! i will remember that ! when the light is lit then it,s out of overdrive, when it,s not lit then it,s in overdrive !
Old 08-01-2012 | 06:18 PM
Jimmy22's Avatar
If you are ever pulling anything and want to turn the overdrive off, the owners manual says to make sure to do it while you are not moving.
bandit1948
08-09-2012 10:46 AM
bandit1948
07-31-2012 12:47 PM
bandit1948
07-29-2012 05:29 PM
bandit1948
07-27-2012 01:36 PM
fastbird
12-15-2008 10:08 PM
