2000 f150 air condition question
Old 08-29-2011 | 01:35 PM
whr1966's Avatar
Default 2000 f150 air condition question
Hello all and thanks for allowing me to join. I have a current problem with my a/c. It only operates on speeds 3 and 4 (med high and high). Any clues as to what may be causing this and how to fix it. somewhat mechanically inclined but not certified.
Old 08-29-2011 | 02:46 PM
Usually the high speed setting is handled by a separate relay.
All other speeds go through a resistor.
I would suspect the blower motor resistor is defective.
Not difficult to change.If you aren't sure what it looks like , get a new one and now you will know what to look for under the hood usually located on the evap ductwork.
Some are held with 2 screws , some with 3 screws. The resistor body has a plug with 3-4 wires on it. Usually easy to replace.
Old 09-01-2011 | 10:24 AM
whr1966's Avatar
Thanks hanky. That cured the problem, a/c works like a charm now.
Grumpygranpa
Mid West
07-19-2010 07:25 AM
erwatt
07-23-2009 06:48 AM
jloprete
09-19-2007 01:38 PM
janglin
07-28-2005 06:12 PM
janglin
07-27-2005 08:57 PM
