2003 F150 starting issue
Old 03-21-2007 | 11:51 PM
Lawnsrusinc.'s Avatar
Default 2003 F150 starting issue
Well hi to everyone on the forum. I have an issue an employee here at work was told that to check the alternator that he had to disconect the battery well that triggered a bunch of issues blew 6 fuses and now it wont start even after replacing the fuses it does turn over but iam guessing it might be a relay any insight other than ur out of luck jason would be much appreciated.
Thanks in advance Jason
[align=left] [/align]
Old 03-22-2007 | 01:34 AM
Default RE: 2003 F150 starting issue
What engine?
Does the fuel pump run?
Old 03-22-2007 | 03:06 AM
goinstrong's Avatar
Taking off the battery cable never blows fuses unless there's major trouble (or you dropped it and it bounced around on the battery terminal). What theyalso might have done(if not what I just said) was to check the alternator first. It likely shorted and fried a bunchof fuses and some fusible links. Then they pulled the cable off. I'd look for a bad fuse link in the ignition circuit. The starter itself and it's major circuit seems unaffected so you can rule out some of that stuff. Look for a bad wire or burnt casing.
oh shoot sorry its the 6 cylinder gaser. Sorry 2x4 2004 manual and the fuel pump is does kick on i did replace the fuse for that. iam not usre if i need to start going through the relays incase one of those burnt 2.
Jason
Old 03-22-2007 | 04:05 AM
Did it pop any of the 30amp fuses..PCM relayor the power feed for the PCM diode ect..
Old 03-22-2007 | 12:24 PM
Hayapower it did not blow any 30 amp fuses i went threw all of them this morning i will be going threw the relays I was actually looking threw the book and going to start with the PCM relay's, PCM diode relay and maybe fuel pump relay. Iam crossing my fingers also i found a fuel pump reset switch maybe i should just try reseting that while iam playin g under the dash
Old 03-22-2007 | 02:24 PM
goinstrong's Avatar
First I'd look for the bad link or relay then I'd take a look at all the fuses just to be safe and make sure someone hasn't tried plugging a low amp fuse into a higher amp slot.
twopugsforme
12-17-2013 03:17 PM
stevelom29
03-06-2013 09:11 PM
Explorer91
05-08-2007 06:07 AM
onepartangel
03-20-2007 10:46 PM
keeper
01-10-2006 09:18 PM
