2006 F150 Radio Removal
Old 02-22-2007 | 02:37 PM
howard's Avatar
Default 2006 F150 Radio Removal
I have been searching I-Net on how to remove my radio from my 2006 F150. It does not have the "holes" in front like my 2000 model. Any ideas?
Old 02-22-2007 | 03:42 PM
Default RE: 2006 F150 Radio Removal
Welcome....
Sent you an email...
Old 02-22-2007 | 04:17 PM
howard's Avatar
Thanks.. our e-mail server is down right now. I will check out e-mail when they get server fixed
Old 02-22-2007 | 04:55 PM
Finish panel clips/snaps to the dash.. Pull evenly/outward to remove.. Also included an exploded view for clarity...
Removal and Installation.
[ol][*]Remove the center instrument panel finish panel.[*]Disconnect the electrical connectors.
[ul][/ul][/ol][*]Remove the 4 screws and the audio unit.[*]Disconnect the electrical connectors and the antenna lead.
[ul][/ul]
[ol][/ol][*]To install, reverse the removal procedure
[ol][/ol]
[IMG]local://upfiles/6756/EE1B12E5E52D44F69DAA1B194EBD8775.gif[/IMG]
[IMG]local://upfiles/6756/DD451CC428FE4E55865F264987415FE6.gif[/IMG]
Old 02-22-2007 | 08:55 PM
howard's Avatar
Are you saying that the cover plate just snaps off with no tools needed?
Old 02-22-2007 | 10:01 PM
The finish panel just snaps on.. It helps sometimes to use a flat edge/hook typepuller to help get behind the panel, more so if you can keep it in the area of the clips.. If you refer to the 'exploded view' (#12)of the dash/panel you can see the clip 'tabs' anchor points,pointing towards the dash slots
Old 02-23-2007 | 08:15 PM
howard's Avatar
Appreciate.. will give it a try over weekend. I want to see if I have an audio out jack on back of radio
Old 02-23-2007 | 09:04 PM
Think there's only the three connectors and the antenna lead.. What are you trying to add in or on?
Old 06-08-2007 | 10:07 PM
jramirezx2's Avatar
I am very curios about this question, since i am trying to add an ipod hook directly to the factory stereo, can you send me any information on how to remove the radio so i can get to the back of it? Thanks
Old 06-08-2007 | 10:45 PM
Same MY/Application?
The instructions were in the 4th post .. Also, if your adding an ipod, you might want to concider a interface adapter from PIE (Precision Interface Electronics).. http://www.pie.net/Plug'n play connection..
supafly223
07-18-2012 12:56 PM
jkelly941
10-08-2011 10:55 AM
Ratpack
03-11-2008 03:56 PM
Jagee
08-18-2006 06:45 PM
gotspeed13
09-29-2005 05:12 AM
