2007 F150 4X4 - jerking
Old 08-04-2011 | 07:02 PM
sspray's Avatar
Cool 2007 F150 4X4 - jerking
I have an 07 F150 4x4, 105k miles. When you get between 1250 and 1750 rpms, it starts jerking. Doesn't matter what speed I'm going. Feels like transmission slipping. The tach and speedometer don't show any change while it's doing this. I can accelerate through it. It doesn't do it all the time, but am noticing it getting more frequent. I doesn't do it in OD. Someone told us it might be the fuel filter, changed it, still doing it. Anyone have any idea?
Old 08-04-2011 | 09:08 PM
What is the speed range on the speedometer when this is happening?
Old 08-06-2011 | 12:51 AM
sspray's Avatar
Hi Hanky. Mostly between 40 - 50 mph but has done it at other speeds when the rpms are between 1250-1750. I was going to have the trans serviced but I've had a couple of mechanics tell me it could make it worse.
Old 08-06-2011 | 11:25 AM
The first thing that comes to mind is the lock-up torque converter.
You just might be in that range where the converter is constantly hunting.
Trans service is something that should be done on a regular basis. If you haven't had it done, maybe it's trying to tell you it's time.
Old 08-09-2011 | 06:24 PM
sspray's Avatar
Thank you. I will take it in for transmission service. Hopefully it will fix the problem.
Old 08-11-2011 | 06:44 PM
sspray's Avatar
On the way home from work today I got a reduced engine power light that flashed on then went off. Any clue what this is? I haven't had the transmission serviced yet, plan on doing that this weekend.
rescue242
12-30-2010 07:45 PM
rescue242
04-08-2007 10:52 PM
mikex
01-11-2007 03:22 PM
mjtmkg
11-12-2006 10:10 PM
vikingsboy
11-10-2006 06:51 PM
