2015 f150 fuel pump continously running / pump out fuel / fuel pump relay
How make your fuel pump run continuously since the fuel pump relay doesn't help. Disconnect the fuel pump harness and tap into the yellow Grey wire and run a lead to the battery positive. Also Disconnect the metal fuel line with blue locks and attach hose drivers side with clamp 3/8 maybe. Works to get fuel for a generator during no fuel occurrence during hurricanes. 36 gallon tanks. You disconnect and splice and reconnect on passenger side. BTW it's already grounded one wire. Good luck!
