2016 F-150 XLT. Intermittent wiper spray
Hi All
My truck is having issues with spraying windshield washer fluid. Sometimes it will spray and sometimes not. The funny thing is I always hear the pump trying. But nothing comes out. Try it a different time, and no problems, a perfect spray.
Anyone else have this problem? Could it be the pump? Maybe the wiper/signal control arm switch?
If you heat the pump motor running , most likely not the switch.
If you disconnect the hose that goes to the spray nozzles , see what you get then. if you get plenty of fluid out there , maybe nozzles need to be reverse flushed .
