4.6L Triton with low compression in cyl # 4
Old 04-12-2014 | 10:45 PM
Clydesdale's Avatar
Question 4.6L Triton with low compression in cyl # 4
Hi folks
I have a '98 F150 with 4.6L Triton with low compression in cyl # 4 @ approx. 30#; all other cyl are at 140# or so. Would it be a burnt valve, bent valve, cam? Any ideas before I rip it apart?
Any harm if I drive it like that? I have not have it on the road yet.
Thanks
Old 04-13-2014 | 06:41 AM
There are a few things you can try to isolate the problem.Remove the spark plug for the #4 cyl and manually turn the engine over in the normal direction of rotation until you get the #4 piston up to the top of it's travel. Then inject some compressed air into the cyl . Listen for air to be escaping out one of the three following places, the exhaust pipe, the intake , or the oil fill hole on the valve cover. Depending on where you hear the escaping air will point to the valve with the problem or piston if coming out of the oil fill hole. If you can you might also remove the R/S valve cover and check for a possible broken valve spring for the valves on that cyl.
Not good to drive it like that.
Old 04-13-2014 | 04:18 PM
Clydesdale's Avatar
Ok, I put oil in cyl 4, compression came up to 90 lbs, released the gauge & cranked again and now comes up to 60 lbs. Guess I should remove the valve cover for inspection. Thanks for the info hanky
Old 04-19-2014 | 07:06 PM
Clydesdale's Avatar
While holding the crank shaft with a Johnson bar, I put air in the cylinder with piston all the way up; the air would give the piston a good jolt. I moved the piston up & down several times while pressurized with air; at one point, lots of air came out from the oil fill hole. I inspected with my Borescope and found something weird on the piston that I can't figure out what it is.
It's the best picture I could get. Does that look like a damaged piston or what the heck is it?
Old 04-20-2014 | 08:30 AM
Difficult to tell from the photo. It could be something that is causing the rings to stick and lose compression. If possible, try to get a better pix so you can see the entire top of the piston if possible.
Old 04-21-2014 | 11:16 AM
Clydesdale's Avatar
Is it possible to remove that piston from the bottom without removing the crankshaft? This is just my spare truck while I rebuild the trany in my F350 so I don't want to spend too much $ as I will sell it once I get my F350 back on the road.
Any idea if the piston will slide by the crank & block?
Old 04-27-2014 | 07:09 PM
Clydesdale's Avatar
Update:
Took the oil pan off today; pressurized the cylinder with air & from underneath, I could hear lots of air pissing out so I stuck a poly hose in one ear and other end toward the bottom of the piston and lots of air in one location. I viewed that location with the borescope and yup, piston has a burnt hole which is also the spot you see in that picture above.
Old 04-28-2014 | 04:42 AM
A lot will depend on the mileage on the engine.
You most likely will need to remove the head , on that side and remove the piston up through the top. You need to remove the ridge on top of the cyl bore so you don't damage ??? the present piston then install the replacement piston. Depending on the condition of the rod and brg you may be able to reuse them.The ridge has to be removed so you don't damage the replacement piston and rings.I have seen this several times when someone used excessive amounts of starting fluid to get an engine started. If that was used , there could be others with the same possible problem coming due. Before going any further, do you think this may have caused the problem here?
Old 04-28-2014 | 03:15 PM
Clydesdale's Avatar
No idea what would have caused this; I recently bought this truck; haven't even registered it yet. Sometimes this week, I'll remove the head.
Will be back with an update.
Old 04-28-2014 | 08:36 PM
When you get the head off you should be able to get some idea of the condition of the other 3 remaining pistons.
