4 wheel drive problem
Old 04-18-2010 | 11:08 AM
dixiestripes85's Avatar
new update. i put the truck up on jack stands( all 4 wheels ) and manually put it in 4hi then put it in gear. all 4 wheels spin but as soon as i hold the front wheels they stop spinning and dont keep spinning when i let go, even when i give they a little help. any idea on what could be goin wrong in the transfer case?
  #12
Old 04-19-2010 | 09:49 AM
Bullitt94's Avatar
Check your front axles and u-joints on the axles to see if something broke. You may have snapped an axle, u-joint, or u-joint/axle yoke.
  #13
Old 04-19-2010 | 10:50 AM
gauge7's Avatar
Did you hold and stop just one wheel, and if u did the other wheel will keep turning. If u don't have a limited slip diff or locker setup diff. the wheel with least resistance will still turn due 2 the spider gears transferring torque when the other is held. After u check that by holding each wheel seperately 2c if the other is turning and that checks out ok, then get a friend 2 get in the truck and give it some gas to apply torque to the drive wheels at a higher speed 40mph. Now all 4 wheels should spin and it would b very hard 2 stop one from turning. Let me know what happens.
Regards Gauge7
  #14
Old 04-19-2010 | 11:41 AM
yea i held both wheels and after i let go nether started spinning again ever when hitting the gas, just the back two spin.
  #15
Old 04-20-2010 | 10:46 AM
gauge7's Avatar
check if front driveshaft is turning while in 4x4 while front wheels are stopped(if turning). If it does spin then u might have front diff problem (broken case pin or spider gears or broken axle). c if u can hear any unusual noise from front diff. If there is no output to front driveshaft to diff then the transfer case has an issue. If axles r cv boot type try 2 push in toward diff while in gear 2c if anything changes, but use caution while doing this as axle might catch.
  #16
Old 04-20-2010 | 06:10 PM
ya im pretty sure that its a transfer case problem. the front drive shaft turns at first when i put it in 4x4 but as soon as i stop both front wheels it wont turn any more even when i let them go. lets like somethin in the transfer case is slipping or not engaging, cause i dont hear any grinding or anythang out of the ordinary. you know where i can get an exploded view of the transfer case?
  #17
Old 04-21-2010 | 06:34 PM
gauge7's Avatar
go 2 parts dept. at dealership and they can print you what you want but tell them you need the printout 2c what your going 2 need 2 replace and buy from them. This way u shouldn't have any problem as sometimes they'll just show u the exploded view on their screen and ask want u want. Make sure u get the tag off the transfer case which is held on by one of the bolts. Also get vehicle door jam info ie: engine, trans. rear diff etc. code #s Any tags from powertrain will b usefull 2 them. I can't remember what your driving but I have good knowledge on Ford products.
Good Luck!
  #18
Old 04-21-2010 | 07:37 PM
thanks for the help ill keep posted on what i find
  #19
Old 05-02-2010 | 04:45 PM
just an update, i took my truck to the mechanic and they its the transfer case thats bad. so now im lookin for a transfer case and will let you guys know if it works out.
Harburmaster
02-16-2009 10:12 PM
ArrowFlinger
11-29-2007 09:40 AM
broncky
10-08-2007 08:59 PM
broncky
10-08-2007 08:59 PM
citroen
03-18-2006 10:55 PM
