5.4 starts and dies if I let go of the gas? stumped
Old 10-29-2008 | 05:00 PM
d1badz's Avatar
Default 5.4 starts and dies if I let go of the gas? stumped
Hello all I have a 1998 expedtion 5.4 , and I am having intermetting issues
with the truck staying on.
When I start the car It will only stay on if I keep the gas pedal
pressed down and sounds normal, no spitting or coughing.
This happened once last week, and 4 times this week.
The wierd part is sometimes its normal and sometimes
it gives me this problem and Luckily it happens at my house so I dont
get stranded.
Any help? I read some vacuum hoses may cause this if so
and certain ones or locations would be great, Thanks
Also read in the forum for an explorer it was idle air control valve.
Old 10-29-2008 | 07:34 PM
way2old's Avatar
Default RE: 5.4 starts and dies if I let go of the gas? stumped
As a guess, I would say the Idle Air Cintrol valve. Your symptoms really mimic a valve starting to hang up.
Old 10-30-2008 | 03:39 PM
d1badz's Avatar
cleaned intake and checked all vacuums pulled battery cable and reset check engine light.
Started fine 5 times in a row, then this morning took 3 x to stay on??
sound like IAC still, should I go for the 46 bucks and replace it
Old 10-30-2008 | 06:57 PM
way2old's Avatar
If it were mine, I would replace it. Aftyer all, it is 10 years old and has moved thousands upon thousands of times.
goatsauce
04-15-2013 09:32 PM
tjrusty
07-13-2011 06:55 PM
gene431
01-10-2011 04:30 PM
snapper1d
12-10-2010 10:26 AM
d1badz
12-15-2008 05:48 PM
