6 cyl 240 motor leaking oil below distrib.
Old 08-07-2015 | 12:32 AM
garycld's Avatar
Default 6 cyl 240 motor leaking oil below distrib.
Help Have 1969 F100 with 240 motor inline 6 cyl leaking oil below distributor at a hole on block.Pulled distributor and o ring is ok. Hole is below the o ring and on housing that distributor fits into. The motor has a lot of blow-by.Don't know if this would push the oil out of the hole.Thanks
Old 08-07-2015 | 08:55 AM
If the PCV system is blocked or not functioning it could allow crankcase pressure to build up and contribute to the problem.
cmoose
02-18-2014 07:48 PM
porterjohn054
11-11-2009 04:43 PM
joseph85750
07-25-2009 12:25 PM
Localscenemedia
12-10-2008 10:16 PM
jhenessee
09-19-2007 09:29 PM
