78 F-150 TAILLIGHTS/BRAKE LIGHTS
Old 06-21-2007 | 02:42 PM
6663A's Avatar
Default 78 F-150 TAILLIGHTS/BRAKE LIGHTS
Hi all, new owner of a 78 f-150 4X4 351m, auto.
Having wiring issues. I put the parking lights on, both sides work(rear). Step on the brakes, left brake light goes on and right side is completely out. All wires underneath look clean and I checked the ground inside the taillight housings of the bed. Anyone familiar with this. Otherwise all my lights work.
Thanks, JR
Old 06-21-2007 | 10:26 PM
Default RE: 78 F-150 TAILLIGHTS/BRAKE LIGHTS
Common problem for 'both' thefront/back lamps is the 'ground tang' in the light socket to loose the ground/circuit connection.. If so, their available aftermarket with the socket and pigtail harness.. You can use a stripped wire/test leadand ground it to the bulbs brass hub, and ground the other end to the chassis ground.. If the bulb functions correctly then the socket just lost the ground...
Old 06-22-2007 | 03:29 PM
6663A's Avatar
I tested it like you said and it worked perfectly.So now I'm off to get a new socket. Btw, one of the wires moves in and out of the socket which causes the light bulb to flicker. Thanks for saving me a lot of time.
JR
Old 06-22-2007 | 03:47 PM
Glad it was an easy fix...
Some of the best vintage trucks Ford ever built IMO...
willy j
09-30-2013 08:42 PM
roeboat109
09-14-2006 06:03 PM
sgiggles
06-02-2006 05:08 PM
ronr11
12-10-2005 10:34 PM
ronr11
12-10-2005 10:34 PM
