79 Hi-Boy??
Old 05-28-2012 | 08:33 PM
rangermark's Avatar
Default 79 Hi-Boy??
How do you know if a 79 f150 is a factory Hi-Boy? I have ran the VIN and nothing was mentioned. Anyone have any ideas?
Old 06-26-2012 | 12:44 PM
Use Common Sense's Avatar
The term 'Highboy' has been used to refer to the 1967-1977.5 model year Ford F-250's, although 'Highboy' wasn't actually a Ford term.
The term 'Highboy' was more of a nickname that came about when Ford switched to a negative arch leaf spring for the 1977.5 model, making it 4-inches lower than the 1977 model.
For a Ford truck to be considered a 'Highboy', it should meet the following criteria:
1. 1967-1977.5 Ford F-250 4x4
2. Divorced Transfer Case (Not attached to the transmission)
3. A Highboy will have (3) driveshafts
4. The front spring pack will have a noticeable arch (1977.5 and later are flat)
5. Rear springs are 2-1/4" wide. 1977.5 and later non-Highboy's will have 3-inch wide rear leafs.
Front axle choices in the Highboy were either the 8-lug Dana 44 or the low pinion Dana 60.
Engine choices were either the 6-cylinder or 360 2 bbl V-8. Steering was either manual or power ram assist.
F-150's built during that time period are NOT considered a 'Highboy'. The F-250's built from 1977.5 and later are referred to as a 'Lowboy' because they sit lower than the 1977.
fordman88
South West
07-17-2024 10:05 PM
highboy4sale
02-11-2013 11:28 PM
sunflower100
03-10-2012 07:58 PM
cctxfish
04-20-2006 01:41 AM
