90 f150 4x4
Old 01-04-2010 | 02:09 PM
mjones's Avatar
Default 90 f150 4x4
Front end vibrates violently and right front binds and grinds when backing up. I have replaced the front shocks. Could this be caused by a bad ball joint?
Old 01-05-2010 | 09:36 AM
Bullitt94's Avatar
That is possible.
Does it do this all the time, or only when in 4wd? Do you have manual or automatic locking hubs?
Old 01-06-2010 | 04:44 PM
mjones's Avatar
No, only occassionally and only in 2wd. However, I don't use 4wd at the speed it vibrates very often so I don't know if it happens in 4wd. It was auto lock but recently converted to manual locking hubs. If it starts grinding when backing up, I pull forward a little bit, back up again and the bind/grind goes away.
Old 01-07-2010 | 12:26 PM
Bullitt94's Avatar
You may want to see if you have something hung up in your breaks. That could cause these symptoms.
country2
04-03-2008 10:21 AM
skip
03-13-2008 11:46 PM
nicknack24
02-05-2008 11:53 PM
demonpitbull
06-24-2005 12:02 AM
SafariTours
02-03-2005 12:22 AM
