90 f150 timing
RE: 90 f150 timing
pick up a chilton's manual first. Second you will have to see if you need to set the timing twice. You will probably have to set the timing with and without the vacuum advance hooked up. Before you attempt timing, you will need to turn (bump starter little at a time)the engine over (by hand when it gets close)until the #1 is at TDC. My 94 has to be set at idle with the vac. advance not hooked up and at 1500 RPM w/ it hooked up (i believe those are the correct configurations)
If you dont have much experience timing, I would suggest getting help. I have my dist.pulled right now and will be having my mechanic (aka dad) who is a 20 year mechanicset mine becuase i dontwant to have to redo it. Timing isnt something you want messed up!
BM
BM
makuloco2000
11-06-2014 03:58 PM
NickTurbo
04-01-2012 10:21 AM
