'94 F150 5.0 EFI truck overheats "codes-311,332"
Old 03-19-2011 | 03:51 PM
fshnthervr27's Avatar
Default '94 F150 5.0 EFI truck overheats "codes-311,332"
My truck keeps overheating, ive changed the thermostat,waterpump,clutch fan, and it still over heats but only when its warm outside. Ran my scantool cuz my check engine lite was on, codes-311(thermatic Air sys inoperative during self test), 332(EGR flow insufficient). Not sure wut these codes mean and could eather be causing my overheating problem??
Old 03-19-2011 | 06:26 PM
Are all the thermactor air pump parts on the truck?
The EGR valve could be working , but the position sensor may have a problem
Has the EGR system been disabled?
What does the radiator look like inside at the cooling tubes, heavy corrosion?
Has anyone messed with the ign timing?
gaborden
08-19-2014 09:17 AM
toddinav
11-05-2012 04:33 AM
mystarcollectorcar
03-12-2010 08:45 PM
