94 F150 Stuck in park
RE: 94 F150 Stuck in park
You could always try starting the truck in neutral. It is possible that it could be an ignition problem. Other than that, when I had this problem I took my 94 5.0 f-150 into the dealership on a recal dealing with a cruise control sensor. I told the dealership that other than my ABS not working because of the bad sensor, I thought the bad sensor was causing me to not get it out of park. He said it would be the first case he's heard of. They performed the recal and no more stuck in park.
Usually if you step on the brake you can hear a click of the solenoind releasing the lever maybe the switch is bad. Might be able to bypass it.
________
Amatuer Xxx
________
Amatuer Xxx
maxpower
06-24-2013 08:58 PM
