94 F150 Wont drive
Old 09-13-2021 | 08:15 PM
frank Meo's Avatar
I'd call them
Maybe they can give you a hint
  #12
Old 09-14-2021 | 08:48 AM
To confirm we know the whole story.
The problem of not wanting to move in either forward or reverse was the reason the trans and torque converter was replaced, Is this correct ?
Who decided the trans needed to be replaced and who did the work?
As raski stated earlier , need more info, just maybe we might be able to determine exactly what is or is not happening. The more info you can provide , the better, thank you.
  #13
Old 09-14-2021 | 10:08 AM
Diego9090's Avatar
Correct .
The transmission had been slipping for some time and was ran without fluids.
The owner , a friend of mine , decided to swap out the transmission.
The transmission that was purchased came with a torque converter so I installed it as well.
  #14
Old 09-14-2021 | 10:32 AM
frank Meo's Avatar
Any unusual noise like grinding etc?
  #15
Old 09-14-2021 | 11:27 AM
Diego9090's Avatar
No sounds at all from the transmission.
Could it possibly be an issue with the computer not communication correctly?
  #16
Old 09-14-2021 | 12:59 PM
frank Meo's Avatar
I don't recall a computer issue back in 94
Not to say you don'y have one
My way of thinking no noise no gears equal no pressure to the front pump
I'd still call the rebuilder
If you got a numbers matching Trans it should work
Have you rechecked your work ?
  #17
Old 09-14-2021 | 02:01 PM
Diego9090's Avatar
Im trying to get a hold of the rebuilder .
Ill double check the work this weekend and try to perform a pressure line test as well as flushing the cooler.
  #18
Old 09-14-2021 | 04:08 PM
frank Meo's Avatar
Pressure test is a great idea
  #19
Old 09-14-2021 | 04:57 PM
I have some resevrations about the rebuilder not insisting that the cooler be flushed if you expected any kind of warranty.
  #20
Old 09-14-2021 | 05:51 PM
frank Meo's Avatar
I do too
there was always instructions supplied with the transmissions I sold
In fact some supplied he coolers with them
Alva Hux
03-17-2021 03:22 PM
mktnnr03159
05-24-2013 10:04 AM
intwtf
03-25-2013 10:20 AM
cajunangi
06-28-2007 08:34 AM
cobrajet
01-30-2006 08:22 PM
