95 f150 stalls when at a complete stop
Old 12-31-2018 | 07:15 PM
Blabla's Avatar
Unhappy 95 f150 stalls when at a complete stop
hey everyone,
I have been dealing with this issue for a year I bought my 2nd 95 f150 it has a 5.0 and ever since I bought it it has stalled at a complete stop and at temperatures above 65 on the colder days it runs like a champ.....
I have already changed the...….plugs, wires, distributor was changed 2 times, coil pack changed 2 times, changed every sensor other than knock sensor, and most vacuum solenoids, smog pump bypassed, cats gutted, fuel pump changed to a bosch,changed the injectors, changed the fuel pressure regulator, alternator changed, previous owner changed computer. please help I am completely stumped
Old 02-01-2019 | 09:35 AM
John937's Avatar
Default Stalling
In my first 96 F150 I hand turned the distributor, a very small amount, and that fixed it.
Old 02-01-2019 | 05:16 PM
Thanks for the update.
Only time will tell.
Old 02-01-2019 | 11:46 PM
Blabla's Avatar
thanks for the reply! but I'm pretty sure that's not what is wrong because I have put a timing light on it twice and set it to ten degrees and tried adjusting it back and forth by a degree and it didn't change a thing.
Old 02-02-2019 | 09:39 AM
Assuming,,,,,,,,,,,,,,,,,,,it is an automatic trans, will it still stall if you put it into neutral before coming to a stop?
Don't know at this point , but need to know if converter is unlocking when speed gets reduced.
Old 02-16-2019 | 09:36 AM
Blabla's Avatar
yes it is an auto and yes it will still stall in neutral...……. I think I figured it out I put a new tss in it and it seems to have fixed it but it hasn't been really hot yet so im not 100% sure.
Old 10-21-2019 | 08:29 AM
nytryder's Avatar
Are you using Ford Motorcraft replacement parts? Have you cleaned the throttle body? Using after market parts can sometimes cause problems you describe. Just some food for thought. Hope this helps.
Noahb
09-10-2018 02:27 PM
Reamrev53
01-13-2016 02:41 PM
dkspattee
12-03-2011 03:50 PM
OLDBLUE87
11-20-2011 07:26 PM
dkspattee
11-09-2011 08:59 PM
