97 F-150 AC Compressor/Cluch issue?
Old 01-09-2008 | 01:22 AM
97F150SH's Avatar
Default 97 F-150 AC Compressor/Cluch issue?
Hello everyone!
I have a 97 Ford F-150 with a 4.2L engine. Last week I noticed a faint squeak when the engine was running. I pulled the belt off and started turning the pulleys by hand. I got to the AC Pulley and found where my squeak was coming from. Also while turning the pulley, it seemed to bind just slightly. Anyhow this evening I was driving home and had to kick on The Defroster. When I did this, it worked just fine, but as it started heating up in the cab, I turned the temp control **** over to cool and it continued blowing hot. I came to a stoplight and had to stop so I started messing with it. Well it turned out that when I was not accelerating, the air started blowing cold. Once I took off from the light, it started blowing hot again. I got home, popped the hood and started looking around. Again with the engine idling the temp control was working fine. I then had a friend get in the cab and kick on the AC. When she turned on the AC, the clutch seemed to kick in okay and the pulley was turning fine, although the squeak was still there. The AC Was blowing out cool but not cold as it usually is. After this, I noticed that the AC Hose (Upper) had some oil residue on it. So maybe I lost all the oil in the compressor or something. Anyway I guess I am looking for someone that could she some light on this. Am I looking at getting a new compressor, clutch, hose? Maybe all of the above? Anyhow any info would be greatly appreciated! You guys can reach me directly at samv30@gmail.com or just respond here. Much appreciated!
Sam
Old 01-09-2008 | 08:09 AM
david paul's Avatar
Default RE: 97 F-150 AC Compressor/Cluch issue?
the oil is a sign of a freon leak u will have to have a new hose and sustem purged and filled with freon
Old 01-09-2008 | 12:28 PM
97F150SH's Avatar
David Paul,
Thank you for the reply. I understand about the freon leak, but does this also explain the squeak in the AC Pulley?
Sam
Old 01-09-2008 | 01:33 PM
david paul's Avatar
no may b clutch bearing goin out
Old 01-10-2008 | 02:10 PM
oldtimer35's Avatar
Also, if you have lost enough freon for the system to not be working correctly, then you have also lost pag oil which is what lubricates the compressor. You need to listen to the compreesor to see if it is making a knock noise, which would indicate the beginnings of failure and possible contamination in the rest of the sysem. One way to check, when you remove the hose, take the one apart at the lower evap hose and remove the orfice, check it for contamination.
apollo
06-02-2017 07:14 AM
milkshake
12-14-2008 03:22 PM
dieselman21585
07-23-2007 02:21 AM
Frank
10-31-2005 12:41 PM
hveatch2
07-21-2005 05:44 PM
