98 F150 Turn Signal Switch Connector
Old 09-14-2013 | 04:30 PM
Peggy's Avatar
Default 98 F150 Turn Signal Switch Connector
My turn signal switch connector is loose. When I lower my steering wheel the blinkers will not work. I took the shroud off and can hold the gray switch connector in place and it seems to work but the wires in it seem loose. Can I replace just that connector or do you have to replace all the wires to? Thanks...
Old 09-14-2013 | 07:25 PM
If you carefully unplug the plug you should be able to see the locking tabs on each wire terminal. It would pay to make sure that the problem is with the wire terminals in the plug before looking to replace it. There should be a locking tab on the sides of the plug that hold it in place . Make sure they are holding it in place when pressed all the way on.
Christie1984
11-15-2012 08:37 AM
Jflores2389
07-19-2012 01:56 PM
wrd0225
04-07-2010 09:36 PM
kerwinq
05-12-2008 09:46 PM
cat
03-15-2006 09:08 PM
