99 F150 XLT 4x4 5.4 Toasted Motor?
Old 08-07-2012 | 04:14 PM
MindRiot's Avatar
Default 99 F150 XLT 4x4 5.4 Toasted Motor?
I have a 99 Ford F150 and the 8th # on VIN is "L". I have been told that only two certain # motors will be direct bolt in (specific # off of valve cover). Others have told me that as long as the 8th digit on VIN matches it will work. My concern is not wanting to have ECU, Trans, And accessories issues. Going from a 99 to an 01 engine. Please if you answer this, know the correct answer. I don't want to have more conflicting information.
The current motor is 99 5.4 and the donor is out of a wrecked 01 that is a 5.4 as well. I was told that it had to be one of two specific engine codes only in order for there to not be any other parts needing changed, like ECU, MAP Sensor, Etc..... Others have told me as long as it's SOHC and 5.4 there wont be any problems. Soooo Which is correct? I am past ready to buy this motor and dont want to pull the trigger if it will cause me to have to buy a ton of other parts to make it work. Please let me know ASAP as I dont want to loose this low mileage donor motor.
Thanks Guys!!
Bringing them back to life should always happen. Crushing / Scrapping should only be for the too far gone....
F150-Utah
10-23-2011 11:10 PM
ponyboi
08-17-2009 02:07 AM
greuelc
05-23-2008 09:26 PM
outdoornut42
12-14-2007 12:21 PM
ponyboi
08-25-2007 03:39 AM
