ABS issue
Old 07-03-2014 | 06:55 PM
obieone1's Avatar
Default ABS issue
Bought a well used 96 F150 XLT, 302, with possible ABS issues. When turning on the ignition the ABS light illuminates in the dash, and goes out on startup, with no problems. However, when bringing the truck to a stop from speed, there often is a pulsating feeling present, akin to a braking and releasing motion, repeated over and over. My first thought was that my rear drums were out of round, so I removed them and had them turn, but achieved no improvement. I've also had the front rotors checked and have been told there is no warping present. Is it possible the ABS system is malfunctioning and causing this issue, without the ABS light going on. Any and all suggestions will be appreciated.
Old 07-04-2014 | 07:04 AM
If you have a copy of the owner's manual, look in the fusses section for the fuse that supplies the ABS . Then remove the fuse and drive the truck . If the problem is gone, it just confirms the problem is with the ABS. If it is still present, could be the rotors.
Old 07-04-2014 | 03:55 PM
obieone1's Avatar
Default Thanks
Thanks Hanky, for the suggestion. And its certainly easy to carry out. I'll get back with the results.
pjhmah
02-12-2013 12:58 AM
2346home
06-22-2010 12:47 PM
Team Gauguin
08-19-2008 12:58 AM
Hutch64
05-31-2007 09:21 PM
Quick Reply: ABS issue
