air conditioner comes and goes
Old 07-27-2008 | 02:20 PM
americanmade929's Avatar
Default air conditioner comes and goes
When I am accelerating or going up a hill or pulling a heavy load my air conditioner quits blowing through the vents when i am on flat ground or going down hill or holding a steady speed the air does fine any help would be appriciated also i have a 98 f1505.4L 4x4
Old 08-07-2008 | 11:59 PM
jhunt47's Avatar
Default RE: air conditioner comes and goes
if it goes to the defrost position then you have a vacuum leak
Old 08-16-2008 | 11:16 AM
andry's Avatar
the problem is low a/c compressor. try check it out.
Old 08-18-2008 | 08:36 PM
oldtimer35's Avatar
A/C system has a vacuum leak. Check the hose that goes thru the bulkhead for chaffing, around the battery area for evidence of battery acid attacking the plastic vacuum lines or the vacuum tank in the right front fender has a leak. You may also have a vacuum reservoir behind the battery.
JDMAN1
10-09-2023 07:50 AM
hurricanes99
11-04-2007 11:08 PM
renech
09-20-2006 12:36 AM
thfrederick
05-13-2006 05:43 PM
JDMAN1
06-09-2005 12:51 AM
