another bent frame question
Old 03-01-2011 | 04:43 PM
almonyspm1's Avatar
Default another bent frame question
the guy i talked to at a well respected body shop told me that the crumple zone on my f150 could not be repaired if it was crumpled or crimped in. it is only repairable if it is bent up or down or left or right. my question is, can it be repaired or at least pulled back to its original position? another question i have is, if i decide to cut the piece off and replace with another piece, do i have to use a torch or is there other tools i can use?
Old 03-01-2011 | 05:00 PM
Bullitt94's Avatar
You can pull it back, it just isn't strong enought to use anymore. I would use an angle grinder with a cutting wheel to remove the old section.
Old 03-01-2011 | 05:21 PM
almonyspm1's Avatar
first of all thanks for replying again. that makes me feel a lot better, i can finish the job in my driveway haha. i have an angle grinder and electronic welder, so work will begin.
Old 03-03-2011 | 12:53 PM
Bullitt94's Avatar
Atta boy! Good luck!
Old 03-05-2011 | 06:11 PM
almonyspm1's Avatar
i actually changed my mind again. my uncle has a porta power (i think thats what its called). he said we can just pull my frame straight and shim the bumper. so thats a lot easier
saltandpepper
12-10-2010 03:06 AM
Y.Dload
01-01-2009 04:18 AM
brianf150
03-20-2007 10:42 PM
trustyt
01-24-2007 01:14 AM
Escape
11-10-2006 10:50 PM
